  • Magne Skutle 3 posts 24 karma points
    May 27, 2015 @ 19:26
    Magne Skutle
    FormatException: Input string was not in a correct format.] when adding a property to a document type
    Hi :)
    I've created my first Umbraco web site, but have stumbled upon an error I don't see how to get around. I created a new document type, HomePage, and tried adding a new property "headline" (textstring). When saving that property I get the following exception:
    It is a fresh installation (newest version installed via nuget) so I haven't been messing around with anything. Any ideas on what might be wrong?
    edit: It might be worth mentioning that I'm running Windows in a VM on my Mac (Parallels). I tried the same on my work computer(all Windows), and it worked without problems. I even pushed the code to bitbucket, went back to my Mac and cloned the repo -> yet, still error on saving the document type after adding a property.
  • Lars Nederberg 29 posts 84 karma points
    Nov 18, 2015 @ 12:31
    Lars Nederberg
    I have the same problem on windows 10 on parallells. Did you solve this?
  • CA Campbell 3 posts 73 karma points
    Mar 06, 2016 @ 19:12
    CA Campbell
    I have the same problem: both on Win 8 dev machine, and Win 2012 VM.
    I fixed it temporarily by uninstalling and re-installing umbraco (latest version) from nuget... but it came back after a while.
    This bug makes umbraco totally unusable ... can't create or edit doc types.
    Has anybody found a cause, solution or workaround for this?
    Mar 06, 2016 @ 20:02
    CA Campbell
    OK, I just upgraded again using nuget... to umbraco 7.4.1
    That seems to have fixed the problem.
